Hondata S300, Post Start Fuel Rate of Decay aanpassing
Berichtdoor kenny_tmt » za 21 apr 2012, 18:20
Omdat mijne b18 wa te rijk draait in de eerste halve minuut, zou ik dit willen aanpassen maar heb nog nooit met deze parameters gewerkt. Iemand ervaring met dit en eventueel uitleg ?
Meer info:
Cold Start Fuel Trim
Post Start Fuel Adjustment - alters the amount of fuel added immediately after starting the engine. This extra post start fuel is normally slowly reduced to no extra fuel over the period of 10-30 seconds. Changing the post start fuel adjustment will alter the amount of fuel and also the enrichment time period.
Post Start Fuel Rate of Decay - determines the time taken for the extra post-start fuel to diminish to zero. Higher values (rates) of decay will decrease the fuel more quickly than lower values.
There are four steps to the decay table. Step 1 is used until the post-start fuel has diminished to 50% of its initial value, step 2 is used until 25% and then step 3 is used until the post-start fuel decreases to zero. Step 4 is a special case when the intake air temperature is very high (about 70 degrees Celsius / 170 degrees Fahrenheit).
  • Re: Hondata S300, Post Start Fuel Rate of Decay aanpassing
    Berichtdoor jonas (R-garage) » do 24 mei 2012, 19:30
    step4 ''four'' is on the wrong place to know ,bring that sensing to your airtube from your airfilter more staybel grades are here to find to max 30 degrees by coldair.
    Keer terug naar Algemeen
