Thanks fellas
Eigenlijk hoog tijd om de speclist van de CN1 eens te updaten...
Engine:
Stock N22A1
Suspension:
- OEM Honda Sport Suspension
Brakes & Calipers:
Stock
Wheels & tires:
Summer:
- OEM 18 inch Accord CU2 A-spec Sigma wheels, sprayed in Moon Rock Metallic (EDM S2000 color) with 225/40/18 Michelin Pilot Sport tires
Winter:
- OEM 17 inch Accord 30th Anniversary Edition wheels, sprayed in Moon Rock Metallic (EDM S2000 color) with 225/45/17 Dunlup SP Winter Sport tires
Exterior:
- OEM Euro R body kit, including fog lights (gasoline version) & OEM Aeroflow trunk spoiler
- Accord and CTDi badges removed from the trunk
- OEM Sport front grille sprayed in Moon Rock Metallic (matching the color of the rims)
- Top & side grille strips sprayed in SSM
- Tinted (smoked) fromt fog light lenses
- Bosch Aero Twin wipers
Exhaust:
- 2,4 type S OEM exhaust (made to fit)
Electronics :
- Autostyle running lights and led parking lights installed in front light clusters
- Carpoint LED interior lighting
- Carpoint LED reverse light
- Reverse cam (from an '06 USDM Civic) installed in rear licence plate lighting fittings (operates through an interface and projects camview on the sat nav screen when the car is in reverse gear, back in neutral or any other gear: sat nav view)
Interior:
- Black OEM Accord floor mats
- Fire extinguisher removed from front passenger side footwell and fitted inside the trunk
- OEM A spec Alu Look center console & dash trim
- OEM Aluminium sport shift gear knob (Civic EP)
- OEM A spec leather / silver stiched shift boot
- OEM A Spec Accord inscripted door sill plates
Nog een fotootje, als toetje.
