wie kan er wiel studs vervangen ?
Berichtdoor ee8project » ma 29 apr 2013, 21:18
ik zou al men 16 wiel studs moeten vervangen van een ep2 naar langere studs wie kan dit of hoe moet dit mvg
ee8project
my honda: ep2 & ee8
  • Re: wie kan er wiel studs vervangen ?
    Berichtdoor Jebus » ma 29 apr 2013, 21:27
    Ik weet niet of je Engels kan? Hier een diy van een site gehaald:
    Got one side done, should be doing the other side on Thursday.
    I'm gonna try to be as honest as I can, no DIY yet, but if by reading you can't do it, then you shouldn't attempt this. Again, this is the method that we used tonight and it worked.
    1. Remove the wheel
    2. Remove the brake caliper (there's 2 bolts that hold the caliper and 2 other bolts that hold the frame/guide or whatever it's called)
    3. Remove the bolt that holds the brake line (located right behind the rotor)
    4. We used an air hammer to pull out the old stud. If you don't have an air hammer, then use a regular hammer, just be careful not to damage the rotor.
    5. The old stud should come out fairly easy without having to remove anything else. If you can't, the dust shield can be bent (you'll see this when removing/inserting the stud)
    6. If the old stud went out without a problem, putting the new one in will take a little bit more effort. You'll see that the head of the stud gets caught in the dust shield, which is fairly easy to bend in order to put the stud back in.
    7. Put the stud through and with a thick washer or a few washers, use a **GOOD** lug nut and tighten it
    If you can remove the brake caliper, then this is fairly easy. If you don't know how to remove the brake caliper, then this might not be for you
    Gewoon uitkloppen met een hamer dus :goed:
    Jebus
    my honda: EP3
    Berichtdoor ee8project » ma 29 apr 2013, 21:32
    klinkt easy maar ik had ooit eens geprobeerd op een vti fusee
    en die studs komen er niet langs
    want dan komen ze scheef en beschadigt ge de schroefdraad
    en dat wil ik voorkomen
    ee8project
    my honda: ep2 & ee8
    Berichtdoor punanied9 » di 30 apr 2013, 05:35
    :denk: amateur
    ne goeien hamer en gaan ..
    punanied9
    Berichtdoor winters » di 30 apr 2013, 06:17
    $1 schreef:$2linkt easy maar ik had ooit eens geprobeerd op een vti fusee
    legt er een stuk hout op en klopt daar op :D
    winters
    Woonplaats: kleine-brogel
    my honda: del sol vti
