k swap packege vraag
Berichtdoor ee8project » zo 10 feb 2013, 12:50
alsje de level 4 pack koop heb je dan alles voor de swap uit te voeren en hem te laten rijden of
komt er nog iets bij ? buiten het afstellen natuurlijk
mvg
ee8project
my honda: ep2 & ee8
  • Re: k swap packege vraag
    Berichtdoor kennytje0 » zo 10 feb 2013, 13:04
    Applications: These packages are tailored to fit the EG/EH/EJ, DC2 and EK chassis only. If you have an 88-91 ED/EE chassis or 90-93 DA Integra chassis please email us so we can put together a package that fits your older chassis.
    K-Tuned has created a series of swap packages that contain everything needed to get your K-swap project completed. With 4 packages available, we have done the work for you, laying out all the parts you'll need to get your swap done right. From essentials, like mounts, axles, headers and conversion wiring to more detailed parts, like the fuel system, pulley kit and throttle cable kits. It's all available in one place, K-Tuned.
    The parts in our packages have been placed in a particular order, showing what we install first and last when we do a swap in our shop facility. You can start with our "Swap Basics" package and add more parts later on as you need them. This is perfect for guys who are planning to spread their build out over time. Of course, you could also take the plunge and order our "Full Turn Key Swap" package. It contains everything you'll need for your swap from start to finish. The only thing you need to provide is the motor. We've done the rest. So, are you ready to swap Honda's greatest engine into your car?
    kennytje0
    Woonplaats: Westmalle
    my honda: civic ej9
    Berichtdoor punanied9 » zo 10 feb 2013, 13:15
    The Level 4 Package includes:
    - K-Tuned Wiring Conversion Harness
    - K-Tuned 4-2-1 Swap Header
    - Hasport Mount Kit
    - K-Swap Axles Level 0 (basic, zou deze toch upgraden als je wat vermogen wil draaien, ik heb de 2.9 DSS assen )
    - K-Tuned Fuel Line Kit
    - K20 EP3 Idler Pulley Kit
    - K-Tuned Shifter Mount Kit
    - K-Tuned Clutch Line Kit
    - K-Tuned Throttle Cable and Billet Bracket
    - K Swap Air Intake Kit ( kan je makkelijk zelf maken )
    - Drivers Side Radiator Hose Kit ( slangen lekken, oem is beter )
    - Heater Hose Kit (slangen lekken)
    - IACV Rotation Plate
    - Coolant Temp Sensor Adapter
    - ECU Immobilizer / Multiplexor Bypass ( kan je niet afstellen.. )
    en je hebt nog geen radiator dan, enz. enz.
    punanied9
