[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 486: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 678: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/prime_links.php on line 121: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/prime_links.php on line 122: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4799: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4801: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4802: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4803: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
 Hondaclub-belgium.be • Toon onderwerp - B16a uit Engels gestuurde auto in kas van links gestuurde
Berichtdoor Shooters » wo 10 feb 2016, 19:51
B16a motor in kas van b16z6 leggen
Men heeft mij gezegd dat er kabels moesten verlengd worden.
Welke zijn dat?
Ik heb een b16a in een kas met kabelboom van d16z6 gelegd.
Komt wel uit een rechts gestuurde auto.
Kan het dat de fiches ook allemaal de andere kant zitten??
Shooters
Geregistreerd: di 20 aug 2013, 09:34
my honda:
  • Re: B16a uit Engels gestuurde auto in kas van links gestuurd
    Berichtdoor Spooner » do 11 feb 2016, 08:47
    Kwa "aansluitingen" van de fiches verandert er in principe niks als je bij dezelfde obd (0/1/2a/2b) blijft...
    De motorkabelboom voor een links –en rechtsgestuurde is kwa aanluiten hetzelfde. Enkel ligt deze in spiegelbeeld (omdat de boom de wagen binnen gaat aan de kant van de passagier en dit is verschillend bij LHD en RHD uiteraard).
    Gewoon een boom uit een linksgestuurde van dat model motor op aansluiten.
    Ik heb bvb een B18C-R (uit ’00 JDM ITR-RHD-) zitten in mijn EDM ’92 EG6. Ik heb mijn originele boom behouden. Enkel de fiches van de injectoren en de alternator heb ik moeten verwisselen met deze van de ITR. Dit omdat de ITR een obd2b was en de EG6 een obd1.
    Je hebt een “ESI”... Ik dacht dat je deze boom gewoon kon gebruiken voor een B16A (beide VTEC). Wel kijken naar de obd’s van motor en wagen en deze op mekaar afstemmen...
    Hier staat ook veel info: http://honda-tech.com/honda-civic-del-s ... c-2987229/
    Quote by Keiichi Tsuchiya
    Spooner
    my honda:
    Berichtdoor jack70 » do 11 feb 2016, 19:34
    u moet enkel de kabel vd lambdasonde verlengen. (4draadjes)
    bij de b16 zit die achter de carterpan, terwijl bij de d16 van voor bij de uitlaatbocht.
    verder gewoon kabelboom d16 overzetten op blok b16.
    jack70
    Berichtdoor B00ster » vr 19 feb 2016, 15:37
    Idd geweoon de kabelboom vervangen van uk naar linksgestuurd. wat er verder nog kan komen is de fuelrail aansluitingen van de aanvoer en retour, die kan bij engelsblok ook nog al eens graag andersom zitten.
    If every thing seems to be under control, you're not going fast enough.
    [/color]
    B00ster
    Geregistreerd: za 05 jun 2010, 07:00
    my honda:
    Keer terug naar crx/del sol
