For The Race Freaks !! Sequential B-series Gearbox
Berichtdoor jonas (R-garage) » wo 27 aug 2014, 15:57
Hi Jonas
Here is the information and prices you requested: -
6 Speed Sequential = €11,600 rated at 295 ft.lbs
High torque model also available = €12,600 rated at 450 ft.lbs
including LSD tripod inner CV joint, hydraulic release bearing but does not include driveshafts, outer cv joints or gear lever
B Series Bellhousing = €920
Driveshafts (intermediate with support + left + right) = €950
Does not include outer CV joints.
Shipping & Duty = €350
Optional Extras:
Standard gear lever blue anodised complete with base = €550
Flatshift = €590 (kit includes basic display closed loop system) + €250 with downshift blip solenoid
Paddleshift kit complete = €4,300
All prices excluding VAT
Further Information for the GTB Sequential
Standard rated at 295 ft.lbs
High torque option rated at 450 ft.lbs
35kgs without bellhousing
Grooved O-ring sealed casings for easy assembly
First gear fixed on main shaft, 2nd-6th slideoff
13mm Teeth width
Large selection of ratios available
Reverse gear and neutral with safety lock out
Plate type LSD 60/40 or 70/30 or Atb type from quaife
Hydraulic release bearing
Big tulips output shafts with tripods
Input shaft to customer's request
Here are the ratios for you to pick from. Please note 1st gear is fixed on shaft due to the size & diameter of the shaft, all other gears slide on so you must pick a shaft with 1st gear already attached, 13 40, 13 39 & 13 38 these are the 3 ratios.
List of final drive ratios are as follows: -
13 66 13 61 13 56 15 58 15 54
List of gear ratios are as follows: -
13 40 13 39 13 38 14 35 16 37 16 36 15 31 15 29 15 28 17 31
16 28 18 31 17 28 16 25 17 26 19 28 18 26 18 25 20 27 20 26
19 24 19 23 22 26 18 21 22 25 26 29 26 28 27 28 22 21
All straight cut gears.
  • Keer terug naar B-Series
