[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 486: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 678: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 115: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/prime_links.php on line 121: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/prime_links.php on line 122: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4799: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4801: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4802: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4803: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
 Hondaclub-belgium.be • Toon onderwerp - Civic EP2: Kort rammeltje tijdens gas geven.
Berichtdoor Steef Civicep2 » ma 08 okt 2012, 16:08
Ik heb een EP2 en heb even een vraagje over een een heel kort rammeltje.
Als mijn wagen stationair draait hoor ik de motor netjes lopen.
Maar ik als ik bv in ze 3 rijd op een rustig tempo en ik geef wat gas bij hoor ik even een heel kort rammetlje.
Dit heb ik bv ook als ik 50 in ze 4 rij. het is allemaal heel even en dan is het weer weg..
Ik merk verder niks geks tijden het rijden.
Ik hoor het nu nl wel al een poosje.. Het is eigenlijk alleen te horen als m'n radio uit is, zo zacht is het.
Wagen heeft nu zo'n 146k gelopen. Nooit trappen als ie koud is ofzo. Vorig jaar nog een beurt gehad.
Iemand een idee? Of iemand hier met een ep2 die het zelfde hoort?
Steef Civicep2
Geregistreerd: vr 21 okt 2011, 20:50
Woonplaats: Rotterdam
my honda:
  • Re: Civic EP2: Kort rammeltje tijdens gas geven.
    Berichtdoor R200TEG » ma 08 okt 2012, 16:46
    Kijk eens de bouten van uw hitteschilden na, er kan wel eentje loszitten
    感じろ。示せ。ワザ、力、喜び。
    ホンダインテグラタイプR
    R200TEG
    my honda:
    Berichtdoor Nasty » ma 08 okt 2012, 17:35
    Heb dit ook met zelfde kilometerstand. Ben ns benieuwdv :D
    my honda:
    Berichtdoor Connix » ma 08 okt 2012, 17:37
    Connix
    Woonplaats: Schaffen
    my honda:
    Berichtdoor vtiprelude » ma 08 okt 2012, 19:10
    check hitteschild rond je kat eens!! ;)
    my honda:
    Berichtdoor Steef Civicep2 » wo 10 okt 2012, 10:51
    Hitteschild is het niet. dat probleem heb ik al gehad. dat was een andere trilling.
    als jij het ook hebt nasty zal het welnormaal zijn...
    heb gister nog getest. als ik heel fijn gas geef houd het langeraan.
    en als ik vol gas geef, ook in. een te hoge versnelling,dan hoor ik niks...
    misschien toch iets wat los zit. ofzo....
    Steef Civicep2
    my honda:
    Berichtdoor Connix » wo 10 okt 2012, 11:26
    Connix
    my honda:
    Berichtdoor Steef Civicep2 » wo 10 okt 2012, 11:51
    Het is haast niet op te nemen...
    Als je je er op focused dan hoor je het, en ga je er automatisch op letten.
    Stationair hoor ik niks geks. En in neutraal hoor ik het ook niet...
    Het komt wel aan de voorkant vandaan, lijkt er dan een beetje op of er iets los is getrild ofzo..
    Heel vreemd dus.
    Steef Civicep2
    my honda:
    Berichtdoor dom » wo 10 okt 2012, 12:12
    uitlaatlijn hangt nog goed vast?
    my honda:
    Berichtdoor Steef Civicep2 » wo 10 okt 2012, 12:16
    Ja dat ook, hij is pas gekeurd...
    Steef Civicep2
    my honda:
    Berichtdoor Pink Danny » wo 10 okt 2012, 22:10
    ik denk zelfs dat het een begin is van een bijna versleten lager in de versnellingsbak... Da zou kut zijn , maar heb bij mij pas ene vervangen , die rammelde ook stillekes... Alleen al wel wa erger dan nu bij u 't geval is denk ik. Lager kost maar 30€ bij honda , maar hem steken is keiharde kut , ik heb heel de motor eruitgehaald om den bak er af te krijgen. 'T is da , of't hele subframe...
    Pink Danny
    Woonplaats: Rijkevorsel
    my honda:
    Berichtdoor Steef Civicep2 » do 11 okt 2012, 07:56
    Hij schakeld andersnog steeds zoals normaal. Soms wat moeilijk in de achteruit. maar dat had ik bijmeerde hondas..
    maar als dat het zou zijn... betekend natuurlijk weer een hoop kosten aan arbeids uren...
    hoe weet je zeker dat dat het is?
    Steef Civicep2
    my honda:
    Berichtdoor jonas (R-garage) » do 11 okt 2012, 18:01
    bak ervanaf halen en voelen aan de primaire as !
    my honda:
    Berichtdoor Steef Civicep2 » do 11 okt 2012, 18:13
    Ja sorry maar t is me daily die ik niet zo ff uitelkaar trek eb heb er ook geen kaasvan gegeten....
    Steef Civicep2
    my honda:
    Berichtdoor Nasty » do 11 okt 2012, 22:06
    Heb je je luchtfilterbox losgehad?
    Bij mij was er een rondelletje niet goed vastgedraaid, en elke keer op een bepaald toerental begon dat te resoneren. Ziekelijk gewoon!
    my honda:
