Acura RDX injectors info
Berichtdoor HondaNickx » za 27 maart 2010, 13:53
Heb al een tijdje van de Acura RDX injectors gehoord uit de K23 I-Vtec Turbo.Nu kwam ik deze mooie omschrijving door "INH" tegen en ik dacht zal dit aan iedereen meedelen.Goedkope Oem honda 383cc injectors met een heel fijn nevelpatroon. :thumbsup:
"The Acura RDX, Honda's first production vehicle in the US that is turbocharged, has brought many new and exciting technologies to the sport compact market, one of which is it's fuel injectors. With what is said to be a superior spray pattern, and a CC rating of about 383 CCs/min at 32 psi, they are perhaps the best bang-for-buck injectors out there, costing a meager $34 each.
With a little bit of effort, you too can reap these benefits.
Above is an RDX injector, part number 16450-RWC-A01, with a Scion TC injector connector, and a set of Acura wiring pigtails. All of these fit together perfectly.
Above is the connector from different angles. You can order it from Toyota, or online from a Toyota OEM parts supplier. Part number 90980-11875
Add to those the Acura pigtails, part number 04320-sp0-e00
And you get this:
Which leads to:
To get these to work on your intake, you need to machine an adapter ring to fit in the manifold I believe. I'll have more info on this later.
At the fuel rail side, you need to get one for 14mm Bosch style injectors. Mr gasket makes one for D16/15's. You then need to cut the little tab off of the injector. I chose to go the easy route and send my intake to http://www.roskoracing.com, as they are quite familiar with RDX injector retrofits, and custom make fuel rails that retain the tab on the injectors and any spacers needed for the rail and intake.
I sent eight Acura RDX injectors to http://www.injector-rehab.com/ to be completely tested in every way they could. Below are the results, as well as the video of the flow test. Posted below are the results:
http://www.youtube.com/watch?v=bmy8bZHugRA
Thanks to Injector Rehab for the great communication and customer service. I wouldn't hesitate to use them again =D "
  • Keer terug naar D-Series
