Ik kwam dit probleem wel veel tegen.
Nu leest ik dat het de o2 sensor kan zijn of de ECU zelf.
Bij deze gaste bleef de fuse springen wat het geval niet is bij mij dan.
Its deffinately a open wire. I would check your o2 sensor wires first, their usually the prime culprits. other then that just keep tracing until u find a open wire in your engine bay. Sucks but not to much else you can do.
i had the same problem at one point but i got a chipped ecu off of ebay and the ecu was bad and they sent me a diffefent one and it stopped blowing the fuses so it could b the ecu!!!!
Maar deze lijkt me meer iets dat ik aan de hand heb,als ik de fouten kan aflezen op de hondata.
Unplug your main relay above the ECU behind the glove box. then try again. that supplies power through the main relay to the ECU then the injectors, evap solonoid, IAC and both O2 heaters.
