Anodize your oem Titanium gear knob using coke and batteries
Berichtdoor DC2 » wo 31 maart 2010, 16:01
Opgelet, werkt alleen bij titanium. Die zitten standaard in de ITR en waarschijnlijk nog andere R Modellen
I was reading earlier today that Titanium can be anodized using coke and 9v batteries.....only thing i had made of titanium was my oem gear knob....well i had to have a try for myself.
what you need is a non metallic container (mug) put a folded bit of aluminium foil down one side of the mug, connected a wire for the negative (note in my pic i have the red and black leads the wrong way round GEARKNOB GOES TO BATTERY POSITIVE, FOIL GOES TO NEGATIVE). i attached my gearknob to a bolt and hung it into the coke (i used diet but i dont think it matters) THE GEARKNOB AND FOIL MUST NOT TOUCH.
the best way to do it is get your gearknob hanging in the coke and make sure theyre not touching before you connect the battery (batteries).
For my first attempt i used two batteries for 18v and got the results below after about 1 minute, a bit blotchy and not really the colour i was looking for.
so i added another battery and put it back in for another minute..... getting more like it now
i then started trying again, adding more and more batteries, but it just started going a bit grey. i sanded it down with a bit of wet and dry in a drill (took about 30 secs) and tryed a few more times. to get it looking like below i had 7 batteries connected together (63v, i think voltages upto 150v are used) and connected the power for about 3 secs, span it round 180 degrees and gave it another 3 secs.this was because i found the side nearest the foil changes colour a lot more quickly.
The idea is that different colours can be gained by using different voltages, but you would usually have an adjustable power supply and better solutions than coke to get a broad spectrum of repeatable colouring. even so, just with the batteries and coke, i'm sure you can get good results by experimenting a bit........there's a lot more info out there on this, i have barely touched the surface.
DC2
Geregistreerd: vr 26 maart 2010, 03:20
my honda: ITR
  • Re: Anodize your oem Titanium gear knob using coke and batte
    Berichtdoor HondaNickx » do 01 apr 2010, 18:39
    Cool handige tip ;)
    Berichtdoor falken » za 10 apr 2010, 15:21
    heb geprobeerd ma denk da de mijne ni van titanium is
    falken
    Geregistreerd: di 23 maart 2010, 20:44
    Woonplaats: Japan
    my honda: cl7
    Berichtdoor DC2 » za 10 apr 2010, 19:38
    $1 schreef:$2eb geprobeerd ma denk da de mijne ni van titanium is
    lol, geen resultaat dus ?
    DC2
    my honda: ITR
    Berichtdoor falz » wo 30 jun 2010, 23:39
    iemand da t al met success gedaan heeft ?
    ik neem aan da de standaard ek9 pook titanium is ?
    falz
    my honda: Civic EM1 VTi Coupé
    Keer terug naar How To
