00" n/a ATR Skunk2 powered (271PS/268NM):
gear oil radiator
engine:
Haltech E6X ECU - standalone
Haltech double-ignition system
SKUNK2 Camshaft KIT (cam, retainer, springs, sprockets))
ported and polished BB1 head
Ferrea Valves -> IN 36mm oversice, EX stock
GoldenEagle sleeved block 89mm bore
GoldenEagle 89mm Headgasket
ARP Head bolts
JE custom Pistons 12,2:1 compression (cubic 2257ccm)
Eagle rods
crankshaft balanced und balance shaft removed
JUN Flywheel
Exedy cerametalic clutch kit
GruppeM Intake
Skunk2 68mm throttle body
RC 440 fuel injectors
Walbro 255 fuel pump
AEM pressure regulator
AEM underdrive pulleys
Hytech longtube custom Krümmer 2,5”
BuddyClub SpecIII exhaust system
Moroso Oil Pan
Mocal oil radiator
Mugen thermostat
Gearbox:
1.2. gear: ATR
3.4.5. gear: ATS gears from the ITR
fd: ATR 4.266
Cusco RS 1,5Way
special oil cooling system
URL=http://img407.imageshack.us/i/96hondaaccordblack484.jpg/]
[/URL]
